when changing the clutch cable....
bigdawg43
When changing the clutch cable should the upper ball ramp (where the cable slides through) slide all the way back? Mine only seems to slide three-quarters of the way back once the cable is in.
Didn't notice when I changed mine out last month. I just slapped it back together and it worked fine. Did you have all the slack out of the adjuster when you measured this?
bigdawg43
most of it. do you know what the recomended length of the cable is suppose to be on an '05 pitbull?
