Gaskets are easy, I have actually made my own from gasket material (Napa). Not sure what brand of air filter you have but you just have to remove the cone to get the air filter out. I use k&n air filter cleaner and oil.I took the double-intake air cleaner off tonight............man.......was I disappointed. Filter was filthy and the only gaskets were the shreds that have now been taken on and off a few times. And it wasn't even tightened !!! I can see why, but I'm really irate.
I won't be able to find another gasket in 1 day. Silicone should be OK as a gasket won't it ?
Do y'all LockTite everything all the time ?
You could clean the air filter by simply removing the tiny screws that hold it to the tube, so in theory the main tube won't have to come off the carb again.
You can buy sheets of gasket material and cut them yourself as a possible solution too. Oops, missed Jonathan's post just above....I took the double-intake air cleaner off tonight............man.......was I disappointed. Filter was filthy and the only gaskets were the shreds that have now been taken on and off a few times. And it wasn't even tightened !!! I can see why, but I'm really irate.
Have you checked for any leaks? No shit the rubber caps on the intake manifold can dry rot and crack. It will cause it to stumble “cough” . It did on myI was so disappointed I did not realize I didn't update latest.......
So I got it put back together last Saturday. Fired it up OK and headed out. Runs fine under partial throttle and up to about 2500 RPM. But at WOT (or near it) at 3K it stumbles, coughs, and just won't run.
I thought it was more carb trouble, but it just doesn't make sense. Then this morning I realized it may be timing advance. No clue how that was disturbed by cleaning the air filter, but it's the only thing that seems plausible.
How does timing advance work on this bike ?
EFI would control it all through the main "brain", and really ancient stuff would be vacuum or mechanical.
What is it on these motors ?
I dont know how many miles u got on those plugs but ur motor is lean....back cylinder will naturally always be richer than the front because of gravity and the force of going down the road will automatically let more fuel go to the rear cylinder...but u still got a air leak or not enough fuelThe plugs are new NGK DCPR7Es. They look OK to me. Nearly white but tan on one side. Guess our flame front is not that even.
Here's the belt too. it has nicks all over it, but they're only on the surface. I plan to soldier on to BBBBQ, finish wearing out this tire, and then change tire and belt this winter. Doing it myself this time........I'll research lifts next.
Front plugs:
Rear plugs:
NGK plug model:
