those lights indicate if I am not mistaken that almost all the circuits are activated. Usually there are only a few lights on.
Personally at this point I would PULL the EHC out and connect Power and ground only
Check for lights
Use a jumper to ground ehc pin for run
check lights only power up yellow
use a jumper to ground start ehc pin
check lights - yellow, green and blue (compression release)
If that passes, I would disconnect as many of the jst connectors as possible and add them back one at a time
Do switches first and watch for correct lights on ehc
add back front TS/RUN - test
add back rear TS/RUN/Stop - test
add horn
etc
Do headlight last.
basically isolate and test as much as you can.
