What fuel do you use?
toomanybikes
not enough time 4 riding
Is it worth saving about $.50 per fill up by using regular instead of premium? Just wish the stations around here did not have the 10% ethanol fuel
Ok... so some of that info Hippy posted (which I know he copy pastes) is true... but alot of it is WAY exagerated.
Floating tank roofs in the big above ground tanks... yes they exist, but it is not about evaporation in the sense that the company looses products its about the fumes they give off. Each facility has a permit on such things by the EPA. It allows them to emit a certain amount of fumes and polution.. each floating gas tank has legs on the bottom at say 9ft or so... even if they suck down the tank to "land the roof" they are only allowed so many per year. Most have to do it to "turn over" their RVP in spring time.
Yes each product has a specific gravity, yes that gty changes with temps and then we (in the industry) correct that gty change to a API standard of 60 degrees. Then you have to calibrate the meters to that days product temps, pressures, and gty. That gives you a meter factor where you multiply the gross meter counts by the meter factor to get the net meter counts or corrected amount. On meters like mine, large pipeline meters they are done daily. On truck rack meters they are done quartly, and gas stations are done I believe bi-annual, which would correct for the opposite extremes. All thoguht my expertise ends at the semi truck hauling it away from one of my facilities.
Now if you want to get in brands of gas discussion I can go there...
Do you want to know how they create the different levels of octane?
Chopper Dave
SIICK!!!
Chris told me last night how they create the different levels of octane.....very interesting...:up:
BBChopper
Supports 2 Disabled Vets
WTF?
I use the same shit these guys use????:eek:
:whoop: Oh yea baby:whoop: Oh yea:whoop:
catch me if you can:hi: Bye Bye:2thumbs:
BBChopper
Yes Gas, how are the different octanes created?
Grades of refining???
If so why is Diesel higher than unleaded. In the 70’s it was 1/4of the cost of regular. Yes now it’s low sulfur but shit it’s still fuel not gasoline…….WTF?
:eek: :rant: :eek: :rolleyes:
Gas will know!!!
Cobrafast1
I use 93 Octane either Shell, Chevron or Sunoco. I NEVER use Citgo. I have a real problem buying the Venezualan gas for Hugo Chavez. He wants all Americans dead, so piss on him.
Down here in SW Florida, Sunoco Turbo-Blue is really hard to find and not usually worth the drive. I used in in Michigan all the time in my show/race car, but only a mix in the bikes.
I never use Mobil. I'll use it in my daily driver. I was told they have lots of detergents in their gas to clean fuel injectors and that will fowl plugs. Since everything I have is carb'd, I stay away from that brand for the toys.
ZZ CHOP
Yes Gas it would be intersting to know about the different octane levels I guess this is somthing with the R&M method...Dave.
Well, I am always interested in new info...
How 'bout the cliff note version.
There is no cliff notes... I'll copy out some explanation I gave a buddy in a email, so sorry for the forward arrows.
This explains a few things on generic gas vs branded gas sense Cobra talked about Mobil.
Which brings us Generic vs Branded gas. Like the old
> > saying "don't buy gas from a gas station that doesn't
> > hold the name of the refinery". The gas it self is
> > the same UNTIL it is put into the semi truck to be
> > hauled to the gas station. What happens is that the
> > actual gas gets a additive injected into while it
> > fills the semi. This is where the differences start.
> > Generic is gas such as Speedway, KMart, Wal Mart,
> > Sams, Admiral, Clark, Rich, Meijer, and many others
> > that aren't list in the next list. The generic gas
> > comes from Mobil, and Marathon, or other places its stored
in gas tank terminals but
> > again changes with the additives.
> > BRANDED is Mobil, Marathon, BP (use to be Amoco),
> > Sunoco, Shell. Side note, there use to be BP & Amoco.
> > BP (British Petrl) bought Amoco (American Oil
> > Company).
> > The govt says that all these oil companies have to add
> > "additives". The additives have different chemicals
> > but mostly the same. The additives contain fuel
> > milage enhancers, cleaners, evironmental crap and
> > other good shit that your motor likes. The cleaners
> > are good for your motor, duh! However, if the govt
> > says you must inject "1" (I don't mean 1 additive I
> > mean just 1 as a unit)that's all the generic gas'
> > gets. However, the Branded gas inject 3 times that
> > amount. This is to ensure that their gas performs
> > better than the generic gas. HERE'S WHERE THE GAS
> > STARTS GETTING MORE DIFFERENT.
> > Branded GAS + 3 additive = Good GAS
> > Then you have GAS + 1 additive(generic) + ethynol =
> > generic gas. Which brings us to ethynol.
> > This is something that the govt is pushing onto the
> > oil companies. It is acholhol. The oil company such
> > as Marathon gets a BIG tax break for using it in their
> > generic gas. They get a tax break at the tank
> > terminal, and the gas station. Here's the incentive
> > for using it. It helps the gas burn MORE therefor
> > cleaner. Cleaner means better for the tree huggers.
> > Now they don't inj. ethynol into the branded gas.
> > Now cleaner burn also means cleaner gas tank. Just
> > think about it, you can clean stuff with acholhol.
> > When the semi's are hauling all branded gas they get a
> > type of "non-luster" to the inside of their trailers.
> > Then they haul some ethynol inj. gas and from driving
> > down the road (splish splash) gets the inside of the
> > trailer all clean. Now we have all heard of these
> > guys saying, I put that ethynol injected crap gas into
> > my "car/truck/bike" and it fucked it up. The problem
> > is that the ethynol has cleaned out the gas tank and
> > all that crud and crap has crapped up their gas filter
> > and maybe injectors. You also may hear about it
> > drying out o-rings and such. I try to use it
> > everyonce and a while to keep everything clean and
> > shinny but not all time.
> > Bottom line....
> > Generic gas gives you less good stuff plus ethynol.
> > Branded gas gives you 3 times good stuff and no
> > ethynol.
> > Now I try to use Mobil, Marathon, BP, or Sunoco.
> > Usually in that order. Then if all else fails
> > Speedway...I generally stay away from anything else.
> > Now this is not every bit of info on the subject but a
> > desent low down. If you have any questions just let
> > me know. I think that makes sense. There are more
> > in's and out's to all of this but it's getting kind of
> > long.
No understand in the time between that email and now... everybody here in michigan uses ethynol.
On the octane... allow me to show you how they create 1 gallong of prem 93 octane gas with ethynol, which is 113 octane alone.
Take the 10% of the 113 = 11.3
74% of 93 octane prem gas = 68.82
16% of 85 octane (sub grade) gas = 13.6
Add it all together and you get 93.72 octane gas.
Now if your gas station doesn't have ethynol then it may be straight 93 gas. If its 91 octane its blended with either 87 or 85 gas.
Even your 87 isn't straight, its usually blended with 86. Hell sometimes they don't even have 87 octane, just 86 blended with ethynol.
On the mid grade 89 octane stuff... that is blended at the pump where you get your gas. its a blend of prem and regular.
next?
