smittybilt
Have a set of older Fats cases. Trying to source a crankshaft. From what I have found so far. Needs to be a five piece with a .25 in longer pinion pin. Also heard you can use the early model Evo 5 piece crank. Are there any other HD cranks that can be modified to work?
Or didn't know about using a newer style Ultima 3 piece... that might come with the correct length pin.
Any help or info is greatly appreciated.
Thanks Kevin
Thanks Kevin
