while driving some sound came and engine died
oguzb
Hello,
i was riding my pitbull today and suddenly died, i try to start it doesn't crank seems piston or something stuck. what could it be ?
SCC007
Sorry to hear. Please describe the sound it made before dying. When you say it doesn’t crank. As in the starter doesn’t engage or it won’t turn the motor?
Start by removing both spark plugs. See if it will turn over freely. @ this point you can drop a bore scope into each cylinder to see if there is any obvious motor damage. If still not turning over, pull the outer primary cover and ck to see the small 7/16 starter bolt hasnt come loose. From there you can begin to eliminate "could be's". Meaning, could it be this or that....ect.
knothead
Second Chance Customs
Or possibly the basket bolts broke and its got it jammed up on the ring gear....possible that a basket bolt broke and is jammed up under the ring gear against the primary bottom locking it where it cant move....like Mr. Wright said pull the inspection cover off....if you dont see nothing clearly pull the whole cover off
