As the Dakota was the last thing you did, revisit it. Its possible you didnt make a total connection and now you have a gremlin. I would pull it back out and start over. Thats just my thoughts tho. Im sure someone will have a better idea. Ck the connections @ your key switch too.Hi
I have an 07 Bigdog Bulldog and I just put in a Dakota Digital speedometer. Supposedly plug and play. Now my engine dies while riding. But starts right back up. No other electrical problems are evident. Has any one had this issue? Thanks for any feedback brothers!!
If you don't see anything obvious, put your old speedo back in to see if the problem goes away. How long did it take after you installed the Dakota for your bike to start failing? It is possible that it's just a coincidence which is why I suggested putting the old speedo back in for a test.Thanks. Going to pull it and check connections. Thanks
