Question on Fork rebuild kit
Jkbrea
Are any special tools needed? I have an '05 Chopper and got the rebuild kit with the fluid. Is it pretty straight forward? I thought I read a special tool was needed for one of the seals???
Do some searching. You can make what you need from PVC pipe. Someone way back posted a how to....
FYI......the bikes originally came with 30wt. oil in the forks. If you want the ride to be a little softer you can go with 20wt.. I found 20wt to be too soft and plan to go back to 30wt., but then I am over 230lbs..
Mickmorris
Well Known Member
I use a long piece of pipe, with a larger ID. than the OD. of the fork tube, and a thick washer on top of the seal. Use it like a slide hammer.
Dimensions of the pipe I use as a slidehammer = 44.5 mm Id. - 2 Inch 0d. - 20 inch length. Thick washer on top of the seal.
Snazzy! I’m frugal. That little ringer tool is the ticket. Cheap & super easy to use.
