scubaman15
Have had my 07 Chopper for a week today and have only rode it once last Wednesday ......BUT I hated the sound of the restrictive MUFFLER so I took matters into my own hands and Modified the sucker and it sounds great!!!! And was chee:up: p !!!!
Step 1 Remove the three alanhead cap screws that secure the end of muffler ..two on the side and one on the end.
Optional Step 2 Remove the muffler mounting bracket from the frame and remove it from the muffler.
Optional Step 3 Slide the chrome shield off to keep it from being damaged .
Step 3 Aquire a 12" long 1/2" drill bit and drill three or more holes into the first of the four baffles the first ones are located aprox nine inches from the end of the pipe and do the same to the other pipe .....now you can stop hear if you just want a deeper sound ....BUT if you really want it to talk .
Step 4 Aquire a one inch water pipe at least 15" long and just hammer out the two baffles that you just drilled ...and you could stop hear...BUT
Step 5 Get a long threaded rod 1/2 or better at least 25" long sharpen on grinder and go to work on the second set of baffles "how much you remove will affect the sound" ...I left in some but not much. You now are left with a two into one exhaust system that has a stock look but sounds great !!!
Step 6 Replace the chrome shield and end piece "The shield has shims to keep the shield from rattling remember to replace these". and rehang the system . Enjoy Cost $19.50 for drill bit , Time One hour 15min . I know I'm fairly new to this forum but I did not see any one who has done this and this will greatly improve the sound and I'm thinking the power also ! Good luck all...
