canalroadracing
Is it possible to use the late model hand control switches (micro) on an 03 BG Chopper? If so, what's the trick?
Thanks
Thanks
If you decide to do the swap I can supply you with the PCB switches that you'll need, just let me know.......Is it possible to use the late model hand control switches (micro) on an 03 BG Chopper? If so, what's the trick?
Thanks
And I will gladly take that 03 prehistoric crap you don't want off your hands!If you decide to do the swap I can supply you with the PCB switches that you'll need, just let me know.......
2
Well said LDO, I wouldn't do it but that's just me. I just thought I would help someone out if the needed some items that I have on hand. After going through about 3 or 4 control switches on my 05 I stocked up on replacementsAnd I will gladly take that 03 prehistoric crap you don't want off your hands!![]()
