surferdude
dry docked
What do you use and what primary oil weight do you use?
I have AMS Oil 75/110 ... do you think it's too thick? :up:
Most run H-D Formual+ or Rev-Tech Primary Fluid, some even run Dexron III ATF, the Amsoil 75/110 Severe Gear is for transmissions & rear end duty....What do you use and what primary oil weight do you use?
if it is too thick and too slick, the clutch discs will tend to not separate when you disengage the clutch.What do you use and what primary oil weight do you use?
