Got Chopper Dave's K9 on the lift. He wanted his charging system checked because he's noticed when hooking it to the tender after a ride regardless of time/miles (1.5hr or 30min ride) it takes a long time for it to go to float. But he never expierences any ill effects to his electrical on the bike. Just concerned by noting the weird battery tender behavior.
So I started to go thru it with my service manual.
Braille Battery at 13.4 volts sitting = Good
Both sides of Circuit Breaker read Battery Voltage = Good
Open circuit when testing stator plug to ground = Good
25 A/C - 50 A/C volts from the stator with engine running = Good
Reading 12.9 volts on the VR side of the stator plug, which is just less than battery voltage = Good
With motor running battery voltage drops to 13.0 volts = ???
Disconnected battery from CB, started bike, and I'm getting rising voltage from the VR. HOWEVER, its reverse polarity (reading negative volts). =====???????
Stator checks GOOD
Battery is GOOD
The VR when disconnected from the battery reads reverse polarity. And when all is hooked up it isn't rising the voltage at the battery.
The manual states "the VR has a built in reverse current protection. This will protect the battery from discharging through the VR..." but with it putting out reverse polarity that makes me think this protection aspect isn't functioning.
All tells me that the VR is junk!
Ideas?
Comments?
Corrections?
Help?
Confirmation?
P.S. Noobs, this is why you buy a service manual for your bike. It allowed me to troubleshoot this problem as I did above. BUY THE DAMN SERVICE MANUAL, for God's sake you bought a $30k bike, you have no excuse!
Stator checks GOOD
Battery is GOOD
Ideas?
Comments?
Corrections?
Help?
Confirmation?
