not the starter maybe
titus722
always on the tender,as a matter of fact the tender turns green in about 10 minutes after hooking it up,my problem is when is hot, all i get is click click, no turn over, head light is brite, battery is good,the clicking noise is coming from behind the cover where u put the key,,,
RRRUFF
Don't forget to check the ground connection down on the primary, top starter mount bolt.
Little-Boo
Well if its coming from the coil cover, I would replace the coil. :loony: I have a thunder heart coil that come with my ignition system that I did not install. It is new make me a reasonable offer and shipping and its yours. :2thumbs: Another part that often fails when the motor is hot is the starter solenoid. You may want to rebuild that or replace it. But for sure if the clicking is coming from the key area than that should be you coil getting ready to take a dump on you. Check again and make sure it's not the compression release doing the clicking. Let me know if you need that coil.
Carlos :D
titus722
im thinkin its the ground, i have had the compression realeses go bad, and it doesnt sound like that,,are there any cks i can do for the coil,,
