:iagree: The Service Manual calls for 20, but I put 25 with lots of red locite.Are you talking about the four 5/16" bolts that secure the pressure plate/spring assembly to the clutch hub? If so, you should be safe at 18-20 ft lbs. I have the bandit clutch and the shoulder bolts get torqued to 25 ft lbs. I believe the stock bolts are supposed to be grade 5 so the 18-20 ft pounds will be fine. Remember to use lock-tight on the threads.
Josh, I went ahead and copied all the pages out of my manual and scanned them and created a "How to" for all of us to use.Alright how tight should I torque. The four bolts that go through the clutch and holds everything in place
