Were does this go and wiring
RubWhore
Asshole Extraordinaire
Anbody know where this goes on a 06 K9 I didn`t take apart and have figured everything else out but this and the wiring need a schematic....I know buy a service manual but if someone has a wiring PDF I would be thankful for the help
PurpleDog
Alicat might be right; however, it looks more like the swing arm bump stops to me. Speaking of, mine are worn out, so if ya ain't going to be using 'em (i don't recommend not)- feel free to hook me up with 'em...:D
RubWhore
Mr.PurpleDog was correct I looked and put them in was the swingarm stops thank you so much!!! Now all I got left to figure out is the wiring
What do you need out of the wiring schematics. There is a lot of them. You just want the one that shows where all the connectors go?
RubWhore
That would work as I just need to plug it all back together and once again it is an 06 K9
This is for a 05 but should be the same for yours. Yell if you need anything else.
Cynbahd
Bump stop that goes behind the frame after the battery box. Should have 2 holes drilled and tapped.
RubWhore
That was it !!! was the swing arm stop now all I got left to figure out is what plugs fit what I guess just match wire colors???????????? is there a schematic around to the bike that has the pinouts for the rs232 connectors to what connector fits what so I can trace with a vom?
Once you lay your harness out it will just fall together. There are few connectors that are the same size that are together so this makes it pretty to put it together. Plus you can match wire colors.
But I can scan the wiring schematic for you that has all the wires but it won't tell you where they go in relation to the bike.
Shrinking it to fit here makes it a poor copy. PM me your email address and I'll send you the original file, it's 3mb but looks a whole lot better.
