Staffy
Help, Help, Help PLEASE.
I would like to install an American Suspension Springer (Dragon) on my '08 Mastiff. Have been in touch with Ted from AS forks, who has been a GREAT help and plan to speak to him further in trying to weigh my options. Here's where I'm stuck and need some help and advise.
If I were to work with the "stock" frame (NOT re-doing the neck/rake), I have two triple tree options - The Batwing (which has a 0 offset) and will give a trail of 3.5" or the Decapitator which will give me a trail of 1.2" (I'm not comfortable with either; from what I read reasonable/preferred trail is between 4"-6")
Now based on BDM's spec's the "stock" trail on a Mastiff is 4.81". Using the trail calculator at RB Racing - I come up with 7.73" - what am I doing wrong (have I got the offset numbers messed up?). RB Racing Rake and Trail Calculator
If the stock numbers do not add up then I'm probably feeding Ted from AS forks the incorrect info and getting back incorrect results of (3.5 and 1.2)
I do realize the calculating trail on a Spring is different, but if I can't get it right with Stock, I have to be wrong to begin with. Any and all help is appreciated. Thanks
