Starter teeth, fluid, questions
Dogbone
IF LIFE SUCKS, GO RIDE
Hi everyone. i was doing my inspection of the primary, Chain very loose as seen in pics but the question is at the end of the starter at the bendix that engages the fly wheel is the teeth on the end that engages first suppose to be at an angle? hard to see in the pics but there are all that way and not worn down. :confused: Man the dum ass dog that had this bike before me didnt do anything to it. let me know if this is right. also inside the inspection plate of the primary, it says to use 1.5 quart instead of just 1 Quart. which is right?:loony:
Wow, that chain is loose. Yell if you need the instructions just yell. :2thumbs:
Dogbone
Had the laptop in the garage runnin through Gas Man's how service the primary but just had those few questions. was looking at his front fork service thread and seems timely. What do you think about the teeth?
Dogbone
well i am fixing to tear down the starter because it will stick engaged sometimes and need to know if i need to replace it. Kinda wierd if it stays engaged, just put it in gear real quick and out it goes....
Little-Boo
Eric is right on, that is the way they are made. I just looked :eek: at my spare starter and that is the way the look on mine. So nothing to worry about there you are good to go.
Carlos :whoop:
Banned
check solonoid contacts, thay could be getting stuck, there is a how to on that, very simple
jimizee028
TRUE COLORS COLLISION
i did the how to on a remanufactured ,reinstalled warrantied starter in less than 2 weeks upon install and havent had the problem again since.....GASMANS how to's are the shit......as well as everyone elses
Dogbone
thanks for the info. Been Polishing all day. Bike looks like new again. DOnt think that IDIOT that had it before ever washed it.
Yeah that all looks good besides chain tightness. Put that into spec and GTG!
Dogbone
only one thing at a time on the weekend. gotta save a little time to ride free. normally ride to work, weekend made for thinking about crap other than that. Birds Bikes, BABES:eek:
RRRUFF
Don't forget to check those sprocket nuts also.
Trans clutch hub shaft nut (Left handed Threads) 1-3/16 socket 150 ft lbs to seat hub 1st, loosen then tighten to 120 ft-lbs - red loctite
Engine drive sprocket nut (1-5/16 socket)
150-165 ft-lbs - red loctite
1 quart primary fluid of choice. I use the HD brand non-synthetic
Dogbone
Thanks Ruff. been checking everything i see. :2thumbs:seen the thread about using mercon/dextron in its place but still go with the old reliable stuff.:D
