breather hose coming from heads to air cleaner
jimizee028
TRUE COLORS COLLISION
we have a breather hose coming off both heads the one comin from the back head goes to the air cleaner.lets say i want to run a stack ..what do i do with this breather hose,cause it cant connect no where on the stack......
jimizee028
thanks al,SHREDDER sold me his stack,well practically gave it to me,even shipped it overnite priority mail...what a guy,and i put it on last nite,i surely love the looks of them,however not so sure about performance...i hear conflicting stories.....
M
McLovin
Guest
If you decide you like it and want to keep it, you can get a "puke can" and use it.
Look at these here:
Breathers
Little-Boo
I installed one of these, got it the idea from Raywood. Not much of a link, just an astrik but it works.
This is their web site
Aftermarket & Custom Motorcycle Parts - Harley Davidson Parts - Cycles
I can post a picture of where to mount it, all you have to do is get a longer hose. Or you can do it like alhall88 mentioned, extend the hose to an area under the dog and be done with it. I would put a filter at the end of the hose.
Carlos :whoop:
Staffy
Another option you can consider - I went to AutoZone, found a small filter and attached it directly onto the check valve - L@@K in my galerry there is a pic of it, looks good and works well. I prefferred that to running a hose all the way to the ground, your call.
As far a cans go, got one from Golan, never used it but is worth considering, you can mount it where you think appropriate. Breathers, Motorcycle Petcocks, Chopper Fuel Valves & Tank Selectors - Golan Products
jimi, I like to keep things clean so I routed mine back to the carb. I have a Wimmer and they make there bracket that goes between the carb and elbow that has a plumbed fitting for the rear breather hose. Keeps it nice, clean and simple.
stlmikie
I wish I had more money.
Ray. You say that is a wimmer. Mine is really close to that but a little different. I will try to post up some pictures here real soon and find out what the deal is.
Yep, just a Wimmer bracket with the elbow then I put on a Green filter. Works great and is clean and neat.
stlmikie
I guess these are just breathers? I know they are but are they just another option ontop what you have on yours?
All the models breathed through those bolts that attach the bracket to the head. This was changed in 05 to the twin-cam style breathing system and those breather bolts are no longer used.
Hey, clean up that carb. Your starting to look like me!!! :D
stlmikie
Funny you should mention the dirt. I did that today after looking at those pictures this morning.
