OK Guys..and Gals.....Before I pull the trigger and order these beauties, will they fit my '04 Mastiff?????
LANDMARK MIRRORS
LANDMARK MIRRORS
Still need the adapters for the 2004 models.....let me look a bit, may have a set around.
And something looks funky with them -- is the stud build onto the frame so you only need a nut at the bottom?? If so then the adapters won't work...
Ray...if that's all you need, consider it done.!!!! Thanks Man..!!!! But if what Chacha says, the adaptors will not work with these mirrors. I have an email in to the tech guys at Landmark Mfg, and hopefully when they return to work from the holiday, I will get a response. You know of any other mirror vendor that makes a similar mirror that will fit the Mastiff...with or without the adaptors???Hip, I have a set of the adapters brand new in the package that I won't use. I can send to you.
Oh, I never found that brake parts I thought I had.
Hope your weekend is a great one. How about trading the adapters for some more pierced girls in the Alley section.![]()
