mirrow/clutch lever problem "help needed"
boydog
I need alittle help here guys . My mirrow broke on the clutch lever side . I removed the complete mirrow from the handle bar , not know that the clutch lever pivots off of it . Is there a bushing kit or spacer kit there some where ? I attempted to just re-attach the arm without the mirrow , but noticed the clutch lever to be really loose , It feels as if spacers or bushes may have fell out after riding without the mirrow post in , need info on this problem , thanks .
mobsta
thee is a sleeve that sits in the control that the lever pivoits on.if the bolt fell off the sleeve may have gone with it.mobsta
boydog
:confused:I need alittle help here guys . My mirrow broke on the clutch lever side . I removed the complete mirrow from the handle bar , not know that the clutch lever pivots off of it . Is there a bushing kit or spacer kit there some where ? I attempted to just re-attach the arm without the mirrow , but noticed the clutch lever to be really loose , It feels as if spacers or bushes may have fell out after riding without the mirrow post in , need info on this problem , thanks .:confused:
chacha
Chaff Your EHC!!
Yes -- there should be a bushing sleeve that the mirror stud slides into...normally it's a pretty tight fit, but if you were riding without a mirror stud in place it could have vibrated out I suppose...
boydog
sleeve
im pretty sure thats what happen , is there anywhere to purchase just the sleeve you know of ?
mobsta
if were me if i couldnt get one from the dealer right away i would carefully pull the other side out.take it to my local hardware store and try to match something up.mat have to cut it but if you want to ride that may be what you have to do.someone on the forum my have one for you.just what i would do.:cheers:
boydog
sleeve
I hope someone chimes in who has one that i can get
chacha
Chaff Your EHC!!
mobsta has the right idea -- Ace hardware and trim down to what you need. Or just run a bolt thru it for now and run with one mirror--which is all you need in most states.
hoat
That shit happened to me while riding in a hail storm in yellowstone. Next morning I "tapped" a extra sissy bare bolt threw there and I have not fixed it yet. I will have to since I just broke my other mirror today. You can fab one pretty easy
boydog
Sleeve
Thanks to Hoat and all that replied ,I fab'ed one up Saturday nite , going to purchase new mirrows ,aset like gasman has on his ,thanks again to all
