PA Chopper
I got a leak from the bottom of my oil pump. It's from theelbow fitting that attachs to the line to the oil filter. Since there isn't much room to work between the oil pump and the frame I'm thinking I may have to remove the pump just to get to this fitting. I figure the fitting needs removed, teflon taped and reinstalled. Does this sound right? Anyone know if the fitting will be able to be unthreaded out of the pump while it's still attached? I've never pulled off an oil pump before so I'm not sure what I'll run into with gaskets, shafts, etc. Is it an easy job? My bike is an '09 Mastiff and it is under warranty but my dealer is about 3 hours away and I don't have the time to get it there. Plus the bike is pissing oil on my garage floor.
Thanks in advance,
Dan
Thanks in advance,
Dan
