04 ridgeback will not start
bigdog
Hello, I just installed a wire plus kit on my 04 big dog and it won't start. :bang::bang:I'm getting spark but, it will not start. I am also getting fuel. Is the coil bad? Maybe not enough spark?
V
Welcome. Did ya get the kit from Jake and have ya tried to contact him?
Timing?
mobsta
did it run before the change?are you getting any pop,back fire or just cranking?
BadBrad
2005 Pitbull
Don't you have to get a key switch or something else when you buy the wire plus for that year, or is it just for '05 and up? I'm sure Jake knows.
mobsta
if it ran before i wouldnt think the coil,did you also change the ignition switch?i thought i read that had to be changed but like v said i would contact jake,sorry good luck
mobsta
when your bike died and headlight,was just cranking then also?could be something with the crank sensor,some have had problems
bigdog
no it wouldn't crank or do anything. I did have problems with it turning off after 7 minutes of running. If I let it sit for 10 min. after it would fire and run fine until it sat for a few days.
mobsta
sorry i called it a crank sensor,04 was cam sensor i dont want someone rolling their eyes,sorry i dont have jakes number,man i wish i could help you more.im sure someone will chime in here,good luck:cheers:
Sounds like a fuel issue to me if it ran before. You have plenty of gas in the tank?
