phatchopper300
I just wanta ride
Clutch has no pressure and cable adjustment has bottomed out? THe cable adjustment is all the way out(on the down tube) and has bottomed out and clutch lever has no pressure on it? I did tighten the clutch nut on primary side to 120 ft pounds. and put clutch basket together and diaphram and pressure plate. I get no movement on the diaphram spring? Any sugg. I did a search and couldn't find any post on this problem. Thanks for any advise. I did check the ball and ramp ass. and looked ok.
