Compression Release help Needed Moved by Dakotabos
rkilpatrick
i WANT TO INSTALL COMPRESSION RELEASE ON MY BIKE. 3 STARTERS LATER IS ENOUGH 4 ME, i HAVE A 03 MASTIFF 107 CI. WHERE CAN I GET THE PARTS AND INSTALL DIRECTIONS PEOPLE?
Then buy the kit. Your bike is already wired for them so all you have to do is install the releases and plug them in to the harness. Takes a special tool to install the CR's though. Also for 03's you will need to put an 02 starter relay in it. If you get the kit from BDM it will come with the instruction on this.
Welcome to the site
Dray
I am having the same problem with my 02 Pitbull and the 107", Can anyone tell me if the heads were machined for the compression release? I have seen different info. on this, Also what is the "Best Starter" to use, unofrtunately I think my starter has seen tooo many cold starts without the compression release already !
