jimizee028
TRUE COLORS COLLISION
I have seen that BDM makes a kit that helps ease the pull of the clutch lever....the name escapes me.....i think its cost is around the $200 mark......
Then i see how alot of you are PRO change your clutch guys anyway.....when you have changed your original stock clutch to lets say this bandit clutch assembly i would assume you automatically alleviate the slippage that seems to be so common but does the lever get easier to pull????I have allready been stuck on the beltway 3 times this year and my left hand was definately feeling it........Does this 'kit' BDM sells actually make it worth the $200 you have dropped by purchasing it????
