lrgk9
Finally installled Bandit setup in '05 Bulldog attempting to remedy the clutch slipping under hard acceleration. Still having some issues - what is the proper starting point for the push rod assembly? Stock says run it in then back off 3/4, Bandit won't work at 3/4. 1/4 gets it close, but if clutch cable is adjusted so no slippage at hard acceleration it is a "violent" shift from nuetral to first. If I increase the cable adjustment to "smooth" shift - it still has some slippage at hard acceleration? Any suggestions?
