If you are sure it's not fuel related then I would pull the EHC (being very careful) and ensure it's full of die-electric grease. Then I would search for grounds. When it restarted did it trip the breaker again?EHC module is black in color. The starter relay is mounted on battery box forward of rear tire. I just reset the relay and ignition module (Thunderheart) red LED came on. Cranked bike and it busted right off, ran for 15 - 20 seconds and shutdown. I guess plugs do get good spark when circuit is made. I just need to figure out what the hell is breaking the circuit. I guess the relay could be a possibility. I'll also take a look at the cam sensor thread for troubleshooting as well.
What did you do to "reset the relay and ignition module"?I just reset the relay and ignition module (Thunderheart) red LED came on.
Have you checked the ignition switch or the start/run switch?I just need to figure out what the hell is breaking the circuit.
Take another look at that relay. Does it look exactly like the one in the pic that KA posted? The reason I ask is because your bike shouldn't have one of those...I guess the relay could be a possibility.
A waste of money, time, and effort in my opinion.I'm about ready to start shotgunning this problem.
What breaker?I'll order a new breaker,...
I'd take a minute to find the thread mobsta is talking about and do some troubleshooting...... cam sensor...
4.2 ohms isn't bad if your talking between the two connectors ON the coil and the 11.8 kohms between the spark plug connectors is also good! There isn't really any reason to check resistance between the wires that hookup there...... and coil. By the way, I am getting 4.2 ohms across the two terminal where the red and yellow wires connect. I have zero ohms measuring resistance between the red and yellow wire.
If your talking about the 30 amp breaker from the VR? It has nothing to do with whether the bike will crank/start.i was going to say try the breaker but i didnt think the bike would crank if that was the issue...
By way of the ignition module.i believe the coil gets its signal from the cam sensor,...
I'm still rereading this post trying to find what breaker is popping...The from the thing that gets me is the breaker popping,...
