Jones
Hello all.
Gotta problem, did a search and found a few short discussions. Can someone give me some direction on this.
2008 Ridge. Heard a god awful vibration from the gas tank …started at 2K and went on from the higher the rev the louder the vibration. The posts I read regarding a noise, or rattle from the gas tank led me to take the tank off and check the rubber mountings….they are all good. I also read about a tube in all big dog gas tanks that is only used on California models. The tube is plugged at the rear of the tank on non Cali models…and so it is. A post I read states that you can use JB Weld on the pipe when it comes loose. Where and how do you do that? Drained the tank and shook it …nothing, no sound. Stuck my finger in the filler and sure as chit. Here is a metal tube pressing on the tank top (inside naturally). The tube feels like it is under tension with a spring. I can push it down away from the tank top and it returns to the original position with pretty good force. The top of the tube is just that , looks like it was cut with a tubing cutter. Is there supposed to be some type of fitting on the end of the tube? I don’t think the tube should terminate like that. Yet there is nothing that fell off in the bottom of the tank. I managed to slide the tube over and up the filler neck and it protrudes up about 1.25 inches. The tube goes down and makes a radius bend and goes to the rear of the tank, to the plugged bung. Id like to rip the damn thing out but its mounted pretty strong. Or just bend it down..cant get the leverage to do that. Any one have this problem before?? What did ya’ll do??
Thanks all Regards Juice
