clutch adjustment question?
DOGESTYLE
DOGESTYLE
2007 Bulldog. I want my clutch lever to engage sooner on the "let out". Do I back off the clutch adjustment more or less??????????????
DOGESTYLE
DOGESTYLE
not slipping and working fine...I have to let the lever out almost all the way to engage and want it to engage ealier
all we can really suggest is to go through the complete adjustment procedure including both the pushrod and the cable and see if that does it for you. if the cable has some age/miles on it, it may be stretched too much. in that case, you may have to replace the cable.
Moespeeds
Back off the pushrod adjuster 1/8 turn at a time until you get the desired effect. If you go too far it will start to creep in gear.
