MikeG
The Doctor
Been all over the post and how to section and have followed the adjustment procedures and did adjust pushrods. I don't think so, but I may have done something wrong because I believe I went 4 turns out and my Dog does not like it. More noise than before I adjusted. Seemed ok for a bit but is really loud now and is more than just the normal tick noise. Once up to operating temp, they really seem to be loud. Please correct me if I am wrong because I want to re-adjust but don't want to screw up.
Originally I started cold, rotated tire till rear exhaust was fully extended and then adjusted front exhaust and went 4 turns out which raised the valve correct?
Then I let sit for about 20 mins to bleed down and I was able to turn pushrod by fingers at that time. Then i locked it down and continued till i got all adjusted.
Did I go wrong somewhere?
Now if i want to readjust them, is there a different procedure to follow to get it back to where it was originally and then only go 3 turns out?
In other words, how do i make sure I get back to an original starting point no matter how many turns I went out on the adjust?
Any advice would be greatly appreciated. :up:
