Staffy
Am in the processes of replacing the sprocket shaft oil seal – (Lip (spring) facing outward for wet primaries and lip (spring)facing inward for dry primaries).
On the ctank case - when one looks at the oil seal “cavity” it is approximately .42” in depth while the oil seal itself is approximately .25” – Question: When installing the oil seal does one:
A) Install it “FLUSH” against the outer crank case lip, or
B) Push the seal all the way in until it meets the “inner” lip
Also, what “sealant” would one apply to the oil seal when installing (the old seal had some blue glue – lol)
Any and all help is truly appreciated.
Thanks - Staffy
Thanks - Staffy
