speed wobbles
what?
had it up to 100+ a few times and never had the wobble. these roads in NJ can sometimes be like riding on the moon..............and with a rigid frame i try to avoid this unless i am familiar with the road i am riding on.
IMO these bikes are not the best at cornering.
hows the meat on the tires...balance wise that is? Somebody else mentioned the cold......tires do need time to heat up.
BigDogBro1
Made in the USA
No matter...I wouldn't want to ride any other!
I think it's somewhat of a suspension issue. I might drop the tail a 1/2" from stock this spring and give it a try.
A windsheild will help with some down force on the front end and keep the big pressure off your chest, however I know, I know its not kool:whoop:
Brew
I have the same issue, usually happens in a turn while going down the highway crossing a mid span on a curved road. I've gotten use to it and know it's going to happen so no worries. It did scare the crap out of me the first time it ever happened though...
TEXASDOG
TexasDog
I recently raised the back end on my Mastiff about a half an inch and it got rid of the wobbles at about 90 and it handles much better in the curves. Plus it doesn't bottom out as much.
My solution is ride at normal speeds and I'm definitely not slamming into a wall with my bike:panic:
That's not what it says at all..
Usually the wall to the compress the front end allows you to tighten it all down while it's square.
All I can say about this is check the bottom neck bearing to make sure the neck is not out of round.
TapioK
There is a lot of sense on Raywoods method, Push all the tolerances omn same direction, if you will. I have been riding with JR behind BBChopper, Ray ,speedo needle bottoming out. No wobble on those bikes. What little I had time to observe
These frames are long, front is long, tolerances while making them were what they were, I bet the designer didn’t think about speed either.
Remember those bikes on -70’s. The rear light of my Kawi mach3 looked 3 feet wide when speeding in dark, CB 750 started wobbling from weirdest reasons... where you sat, wich way and how much you leaned on seat..... sensitive beasts. On straight Honda calmed down when you were lying on top of it, face on speedo and legs on rear blinkers
Brandon Downey
You shouldn't be getting a high speed wobble. I don't think the tool bag has anything to do with it - unless you have lead or some heavy Kangaroos in it maybe....:D
I haven't taken the wifes Coyote to those speeds (similar to the Mutt) but I have the K9 plenty. I'd check your alignment and fall-away for starters. How many miles on it - bearings good I presume along with fork oil serviced as needed?
I see it's an old thread, however after reading through it all I have never heard of fall-away. What is that?
Psycho
Psycho
I know the feeling from the 70's very well myself ... Almost had my last ride on my H1 riding it home after purchase !!!
