NO POWER TO BIKE!
str8jakit
Bike has been sitting for a month with the tender on it i go to start it and it tries to start twice like it normally does when its been sitting for a long time.
then then the third time i go to hit the start button, Nothing no power to the whole bike. Battery is not a issue because it is not doing nothing when i turn the key. NO POWER TO THE BIKE. I thought either the ignition or a fuse is bad but dont know if this bike has fuses. So i come to where the great mines gather for a little help if yall would be so kind. thanks:cheers:
GDOG_PITBULL
Hmmmm....a few things to check
ECH connector on the ECH, circuit breaker, fuses, little green wire on the starter...
Try those
G
str8jakit
also like i said it tried to start twice just like it always does just was to cold then the third try power went out to the bike.
GDOG_PITBULL
Do some searches here on the forum threads and you will find just about everything you need. Any fuses should be in a fuse holder so that may not be an issue. Make sure the battery is good under a load!!!! I would also disconnect and reconnect the battery as a possible reset on the ECH.
G
GDOG_PITBULL
that cool i will but is there a circut breaker on this bike.
Not sure on that year but I would think so. Look for a small item mounted flat with wires on both sides. There will be a little reset button and may be hard to see. Try resetting it.
G
RADAMS445
RADICAL
Pop the seat and see if any lights come on after cycling the run/start button. Either the EHC or the ignition mod. should light.
