S&S Rocker Box Part#
BigD07
I was getting ready to order the S&S Rocker Boxes to switch out my TPs on my 06 Mastiff. After looking through several threads i have seen several part numbers associated with them, just looking for the correct one. I have seen: DIE CAST RBOX 99-09 T C [90-4110] and DIE CAST RBOX 84-99 EVO [90-4095] these where out of Drag Specialties. I was thinking it was the 90-4110 but just wanted to make sure before i order them. Thanks for any help.
john sachs
You would be right. Same as Twin Cam. :up:
John
Little-Boo
I got mine from the dealer and the part numbers are
BDM100-00083 Rocker Box Set
BDM100-00081 Roller Rocker Arm
BDM100-00080 Shaft Rocker Arm
103-000067-00 Top End Gasket set
Carlos :whoop:
WhoDey
Carlos :whoop:
What kind of price are we looking at to do this ourselves.
Thanks
Little-Boo
Thanks
I don't remember the full amount, but it was close to 1K or so. I got mine from Full Throttle BDM Dealer in Michigan. I don't have the reciept in front of me but I can get you an address. The dealer was recommend to me by Gasman. I got a 10 or 15 % discount and free shipping.
Carlos
RRRUFF
This was my price list a litttle over a year ago. I cut this price just about in half by shopping around, eBay and such though. 90-4110 is the correct S&S part number.
Rocker Box Set, DC Chrome $594.95
Shaft, Rocker Arm, (Set of 4) $39.95
Roller, Rocker Arm, (Set of 4) $474.95
Kit, Gasket, Top End for S&S $109.95
Kit, Gasket, 117" Rocker Box $59.99
Gasket, Exhaust $3.99
Gasket, Cylinder Base, 4 1/8" Bore $5.99
Manifold O-Ring 5.375" $6.00
Gasket, Cyl Head, 4 1/8" Bore $11.99
BadBrad
2005 Pitbull
Like Carlos, I shopped around (mostly Ebay) and got the entire set with gaskets for about $1K. It will save you so much more in the long run.
