replace headlamp
big A
new to this post. havent had time to look around much. trying to replace the headlamp in my 2004 chopper. i did find a thread that talked about it. i do have 4 holes in the bottom of my bucket but i swear i dont have any allen screws. HELP. am i losing my mind or just my patience. thanks for the help
erldawg
The hex screw as shown in the above post is in the front most hole 1/16th" hex wrench. Use a heat gun on the area of the hex screw will help get it out. Then turn the decorative trim ring ccw, helps if you put on a pair of rubber or latex gloves. (available at Auto parts store)
Welcome aboard..
phatchopper300
I just wanta ride
. This is not funny but I was installing a new bucket and after taking out the 2 allen screws out on bottom the rings were like glued in place. The bucket was trashed anyway with a big dent on front lip so I took out my fustrations out. Now its Kinda funny having to peeling it back.:D I hope you don't have this kinda trouble.
Trainguy
Chromeoholic
Your right that's not funny:roll::roll::roll: What a mess. I put anti-seize back on the threads when i reassemble for next time. The ring and the set screws.
DeputyDog
WOW !!! Ok Mike...calm down...step away from the motorcycle and take the pills the nice people in white gave you. It will all be better after taking a little nap. :)
big A
just bought this scooter the other day and im still going thru it to check everything. the previous owner has a fork bag on the bike. i looked inside and he had a spare headlamp. this wasnt a spare bulb. it was meant to replace the bad one. i couldnt find the allen screw cause it wasnt there. he took it out but couldnt get the beauty ring off. i just might have to beat this one up to get it off. wonder how much a new headlamp assembly gunna cost me. THESE TOYS ARE EXPENSIVE!!! lol
phatchopper300
I just wanta ride
There is one on eBay now. Thats where I got mine. Shovelheadkicker was the seller great seller of BDM parts. Got a new bucket for $57.
phatchopper300
I just wanta ride
Yep they took the white jacket off me with straps that kept me from hurting myself . LOL
RRRUFF
Put some heat with a heat gun so if there is some locktite that should loosen it up. Use rubber gloves as mentioned above to help with getting a grip on the ring. You can also take some duck tape and wrap your thumbs with the taps sticky side out and that will help you get grip. I used a soft hammer and lightly tapped around mine to loosen some rust in the threads. Be sure to put some neversize on the threads when you put it back together.
big A
Well I feel like a jackass. Found out that the headlamp assembly is made by Headwind. The outer ring doesn't slip off. It threads off. It's is amazing how easy things work when u know what ur working with. Anyway, got the whole assembly apart and put back together with a new bulb and lens.
