Killerwart is Looking for some help!!
killerwart
Hello and good evening. I am looking for some help with my Pitbull's speedometer. I have accidentally held the trip button down to long and reset the "PULSE" mode and I am looking for the number code to set back to stock. Anyone familiar with this situation?? Thanks in advance for your help.
Coolbreeze
Have you riden it since you did that? To put in calibration mode you gotta hold the button down then turn the key on at the same time. I'm wondering if you really messed anything up. Pulse count for the pitbull is 101000. If it is cleared you will half to recalibrate the speedo. I can get you the instructions on how. You will need to know a known 2 miles to ride. I usaully use mile markers on the highway.
killerwart
Thanks there man. I have rode it since then. How do I go about recalibrating the speedo? I do know a good two mile stretch to do this. Thanks again.
The pulse code is on the back of the speedo unit :cheers:
shooter
VDO speedo? hold trip button and turn key to on, press trip button till "pulse" displays wait and current pulse count will displays each digit will flash one at a time as they flash you can press trip button and adjust each number, once it passes each digit the display will stop flashing and turn key off it will stay at number you programed. hope this helps raywood said the pulse count is on back of speedo and i believe him my 02 Bulldog has adjusted down to 68000 and still reads low wont seem to adjust lower. :confused: still reads 10 mph low.
