Johnnieye
I have a 2003 Bulldog with 4800 mi., when I hit the start button the starter sometimes makes just a spinning noise and sometimes tries to crank the bike over. I have replaced the battery with a Deka, 310cca, same problem. I tested the new battery with a voltmeter, 12.9v before starting but the voltage drops to 9.8v while trying to crank the bike over the first time. After three tries the voltage drops to 9.6v when trying to start and 12.4 when not. I'm thinking the new battery is bad. What should the voltage drop be ? Could it be something else ? If it is the battery, any suggestions on brand /size ? Any help would be greatly appreciated. Thanks
