Pull your tank and check for grounded wire along the backbone. Common problem and so you need to go over the whole wiring system.Anyone know what would cause my turn signal to flicker on and off ? It's not the switch as the rear does not flicker. Front and rear blink ok when activated , but front left continues to flicker.
cool Rabbid...glad you got it taken care of!:up:Could'nt find the problem today , so i fired it up and went for a ride. Got about a mile from home when it started firing on one cylinder , Pulled over to find the front plug wire came out of the coil. Turned out the 90 deg brass connector inside the rubber boot had broken in half. Made a temp repair to get it home , at which time i noticed the turn signal was no longer flickering. The flickering was evidently caused by arcing of the spark accross the broken connector. Bike is running awhole lot better now with new plug wires which is a plus....:up:
Rainman , See my post #12 and you will see what my problem was. I repaired the broken spark plug wire connector going into the back of the coil and the problem went away.Rabbid, when you figure it out let me know. I have the same problem, I have taken my tanks off and trace to two front wires to the grounding block. The ground is good. The only place where the wire goes is into the EHC. Which at this point I'm thinking is bad. There is no where else that controls that left front turn signal. I've been scratching my head for months now. I don't want to go buy a EHC for 250 just to test it.
