Ignition module...I think...help
drbalazo
Decided to start a new thread since i think i have narrowed my problem down to the ignition module, thanks to you all. When the bike runs long enough to get warm or hot, it shuts off and won't start and the red light won't lit up on the ignition module. I let it cool down and it starts right up, obviously with the red light on. Is my module trashed?
drbalazo
I started the bike and took a heat gun directly at the ignition module. As soon as it got hot, the bike died. I'm assuming the module is trashed, right? If so, can i just replace it with one of the local Harley shop?
Gatlin5
Sure sounds like you got it,
Exactly same symptoms for me. I finally used the heat gun when I was 95% sure it was the module and same thing occured. Depending on the model of ignition module you have, in my case the Twin Tech 1005 it says if no red light flashing when cranking to check the white wire with black stripe to see if you have 12v with the ignition key in the on position. If you have the 12v then the module is bad. Here is the sheet on mine look at the trouble shooting chart on the last page. http://www.daytona-twintec.com/download/Model_1005_Ironhorse_Instructions.pdf
BTW, mine runs fantastic now after swapping out the unit. I went with a Crane because Twin Tech was no help at all. I had to find that chart on my own, I tried emailing Twin Tech a few times and their reply was take the bike to a qualified technician. They could at least have sent me this pdf or told me were to find it.
Best of luck!
Gatlin5
I have a thunder heart module. How do I know which model of module is it?
I took the points cover off and it was right on front of the unit. My bike originally came with a Thunderheart but it was replaced, probably for the same reason by a previous owner to a Twin Tech. Might look on the Thunderheart web site or contact them and see if they have a simple procedure for testing it. Also do a search on Thunderheart ignitions here I remember seeing a number of threads on it.
Best of luck.
Little-Boo
I am glad you decided to follow up with the heat gun like I mentioned.
Now call this guys and tell them what you have and get a new one
Thunder Heart Electronic Products
Carlos :whoop:
drbalazo
Ok i tried calling thunder heart with no success of getting someone. I called gsm performance products and I was told my part number is ASM5000BD-04. Is there a difference in the ASM5000 FTM?
RubWhore
Asshole Extraordinaire
Call Thunderheart directly and order as you dont reely want the BigDog module if you reed on here there are all kinds of posts from us guys that have done this upgrade shood cost less than 200 bucks and reed the how to`s night and day improvement over detuned stock module and its easy to do
drbalazo
Just ordered it from thunder heart. Next day shipping! Can't wait to get this puppy up and running. Thank you all for your much needed help. This site really rocks!
RubWhore
Just remember to read the destructions cause you have to make won adjustment for the tach and thare are instructions posted on this site
