MemphisChopper
I owe ya big time..thanks... Il give it a shot!
Interesting test setup, dogvet - nice to see some real data! :up:I've done regulator testing with Compfire, Thunderheart, H-D, Crane, and the production regulator and they all work fine. None have drawn more than 30 amps even with a variable carbon pile load applied to the battery drawing 1/2 of the cold cranking amp rating.
If you blow the fuse, chances are that you just toasted your regulator! The fuse goes there to protect the bike from surges from the regulator, the only things in line with it are the regulator and the alternator. The fuse is supposed to react to a surge faster than the mechanical breaker. The surge can take out your EHC (ride over). Put a couple of star washers under the new one and get back on the super slab...shiny side up of course!:zz2cents:The fuse is a 40 amp as noted. I checked and they have them in stock at Autozone here in Va in the 40 amp as well as other ratings. Seems to be readily available locally![]()
But if you do blow a fuse are you going to install another with out checking the cause![]()
Thanks V
But as Dave noticed this weekend that although my VR is bolted directly to the mount, his has some spacers between the VR and the front motor mount.One thing that I found interesting was that by adding star washers between the regulator and frame (like Harley does), you actually increase the charge rate at low rpm. Adding the 40 amp fuse is a good idea (but you should make sure you have a spare fuse handy. It's a big sucker and I doubt if they are readily available anywhere but a BD dealer!
:zz2cents:
Star washers are still a good thing because they dig thru the chrome on the regulator (which can be a crappy hi current conductor) and sometimes not all of the powder coating gets removed around the regulator / front engine mount portion of the frame which can ultimately result in a poor ground for the regulator. Again, I'm no expert, just passin on some personal experiences and observations.
:zz2cents:
