WTF is your problem here. Every comment you made is negative, Meanstreet advertises this front end 16 over with 5 degree rake, im sure they have their shit together more then you do. If you dont have anything decent to stay dont say anything at all.A standard wide glide front end is 24-1/4 so when you say 16 over you are saying 16 over the 24-1/4 length. You seem to have your own method so good luck.Rake and trail measurements don't lie. So you can drive your new log roller.
To answer your question .............. from top of lower triple to center of axle its just shy 39", and rake is 37 degrees.Whats the neck rake on the 04?
Pretty sure my 05 is 39 degrees.
My 5 and 12 raised my front about 5/8"
If I went 5 and 16 I'd think it'd be up about 2.5"
The 73's look real good but I question wether its actually 7 degree raked trees or actually less then 16 over. Maybe meanstreet calculates different.
Top of bottom tree to ctr of axle is 37.675" on my 5 + 12 ultima
Who you talking to Hugo or Mike Hanlon at mean street? I know both of them and I am not being negative but with 37 deg rake and 5 deg trees its impossible for your trail to be correct hence you would have a log roller. I've put a few front ends on my personal bike so I don't need to explain to you. They must be quoting 16 over from some other place. Ever since Tim Hanlon quit mean street that place has went to shit. I had to return my front end 3 times to get it right. Look up my posts if you need pics.WTF is your problem here. Every comment you made is negative, Meanstreet advertises this front end 16 over with 5 degree rake, im sure they have their shit together more then you do. If you dont have anything decent to stay dont say anything at all.
Whats a log roller anyways??????/ Lets see what gem you ride.
Big tubes look nice Roman!
