Well yes, I need a little help. Got a wire hanging loose. It is a black wire that comes from the ehc on the right side and had a spade connector on it. I think it is a ground, but don't know and don't want to ground a wire that isn't a ground. I had a starter problem and had it out so probably screwed it up myself. Now after starter is replaced headlights don't work, comp. releases aren't working, thunderheart lights up sometimes and not others?? Ain't sure but am hoping this wire is the reason. Out of the 5 wires coming out of the right side of the ehc it is the middle wire on the outside(right). A little help sure would be appreciated. Need this thing to run while weather is this great and got a couple days off. Thanks.....Dammit
