LukeDM
My dad has an '06 K9. The inner primary cover is stripped out where the bolt holds on a ground wire from the battery, goes through the starter and into the primary. What's the best way to fix this? Could we take off the outer primary cover, drill through the bolt hole and jb weld a bolt to the inside of the primary so it lined up with the starter and put a nut on the outside? What are your suggestions?
Thanks in advance guys.
