2003 Big Dog Bull Transmission Drain Plug
RWBischoff
I may be blind - I cannot find the drain plug for my 2003 Big Dog Bull Dog Baker 6 Speed RSD transmisson.
There is an alen set screw located on the bottom between two other threaded holes - is this it?
Can someone help me and perhaps provide a picture?
Thanks - Ric
Thanks - Ric
Look underneath and at the back of the tranny you will see a black hose attached to the frame with a plug in the end of it. Thats your tranny drain hose.
Tim
Founder
Lifetime Supporting Member
There's a problem, 2003 didn't have a RSD tranny... :confused:
Mojo
Thanks - Ric
All 2004 Bulldogs had right side drive. I don't remember if any of the late '03 Bulldogs had them. These were not the BDM Balance Drive, and the Bulldog was the only model that had it. Regardless, the allen screw you are referring to is the transmission drain. Apply liquid teflon to the threads when you re-install it.The black hose that attaches to the frame is the engine oil drain.
  • Like
Reactions: Tim
Five Five
On your side cover of your transmission where your clutch cable is you will see a series of allen bolts which bolts the cover to the tranny .... the bottom bolt in the very center is the drain plug .....
Five Five
dis-regard ....my instructions are for LSD...
Tim
Founder
Thanks for the heads up on the '03 and '04 Bulldogs, I thought it was strictly '05 and up. :cheers:
Ratman
That do be the little bastard. Don't be surprised if you have to cut/grind off the "short" end of an allen wrench to make it clear those oil lines. Good luck!
DairRizenday1
2002 Mastiff
That is exactly where the drain plug is on my 2002 Mastiff 5 spd. LSD. It is a #40 Torx head plug and tighter than a bulls ass. Save your knuckles; Wear gloves . :cheers:
Rod p.
Thanks - Ric
Mine is between two bottom screws were clutch cable goes in it's an Allan if nothing comes out it's probably because they're is nothing in it. There's another one on bottom but it's hard to get to.you can't get all the oil out anyway gears and shafts and dog,s are covered many in a year it will run out lol
