JeffM
Hi all,
I am having trouble getting my head around a few threads regarding the amount of plates and disc's in the clutch.
I don't want to pull covers off and count plates as i don't have a BDM dealer on the next corner who i can buy parts from.
So my questions are.
1. How many plates/discs should i have for an 07/08 K9?
2. Whats this changing from 12 to a 9 pack i keep reading about, and why and how does 9 fill the void of the 12?
3. My Manual tells me nothing about plates except heights of the packs, but does not explain how this is done and what you are measuring.
4. Push rod length, why is this important? Surely if you still have thread on your push rod through the nut the lenght is irrelevent?
5. Then there is the internal and external teeth, again with the different amount WTF!!!!!!!!!!!!:bang:
6. Is there someone out there in BDM land who has the wisdom of Solomon who can make the waters clearer to this mear mortal
7. Who is the best supplier to export me the correct quality parts to make my Dog bark?
8. Would a different brand, type of clutch make a difference? My clutch is lighter than Attitud2's 250 and all i have changed is the pipes so no big power gains, but still it is slipping and can't get neutual while stationary, it also creeps forward while stopped and the clutch is adjusted perfectly.
Thanks in advance.
Jeff
Thanks in advance.
Jeff
