Thunder Heart EHC
GDOG_PITBULL
I got this and then no further responses to my questions:
Case Ref: "1-30190" - 2004 BDM hand controls to TH wiring
Greg, 2004 and newer Big Dog motorcycles use momentary push buttons hand controls that are not compatible with the EA4260 (MHC).
Are you using the stock push button hand controls?
Sincerely,
Keith Kittle
Thunder-Max Customer Support
MossBerg590
Sincerely,
Keith Kittle
Thats what the momentary switch converter is for, to switch the big dog momentary controls to latching controls so jt can be used with the 4260 module.
MossBerg590
I think if everything is wired up correctly, because you have an 04 it may be the boards on your model isnt working properly as Curtis said. Talk to him about the updated boards and that may fix the problem.
GDOG_PITBULL
Thanks, maybe an additional module would help for signals and brakes???
G
You don't need anything special for the hand controls.
I have installed a number of these kits from KMW and I can tell you they have done nothing special for the hand controls.
I can also tell you from personal experience that the older style PCB board does not work in all cases.
I can't tell you why only that I have had a couple of situations where the old style board refused to work with the kit. After installing a set of the newer PCB boards all the issues went away.
The info I gave earlier about the voltage came right from the horses mouth so doubt it if you want.
Okay, not gonna argue I haven't had the opportunity to play with any of them and you've installed plenty so I always go with the guy who's done it before!
I guess why sell them over the standard thunderheart? $+250 for some JST connectors? Or are their other benefits to the RIP kit ? Now I'm curious :)
MossBerg590
All the wiring is already seperated, shrink wrap, connectors crimped etc.. Saves a lot of time and it is preferable but in my case, being 26 with 4 kids, I couldn't afford it. That's why I went with just doing it myself to save money.
GDOG_PITBULL
Curtis,
Is there a separate module that can be added for turn and brake signals that will work with our controls?
GDOG_PITBULL
The issue is getting 12 vdc in to the command leads of the 4260 to trigger the output leads to blink. Our hand controls do not provide a 12 vdc source so I assume I need a relay that will trigger via the close loop from out controls.
G
DRBarnhart
Insert title here...
G
The controls would have a 12VDC source (from pins 25 & 26 of the 4260) after you wire up the Thunderheart. Example: The kill switch wiring would be pin 26 of the 4260 to the kill switch. Then, from the other side of the kill switch, the wire would go to input 1 of the 4093. Output 1 of the 4093 would then go to pin 32 of the 4260. True?
That would give you 12 VDC inputting to the 4260...
Dennis
PS Keep in mind this only my example and is not all the wires involved!
GDOG_PITBULL
Dennis
So I have taken all motor and starter, comp. rls, and ignition out of the controller. I have a very cool solution for that. All I need is hi / low beam, R/L turn signals, and brake light from this thing. I am assuming there is no voltage across the switch controls and it was just circuit closure for something inside the original EHC. Probably cannot even use the 4093 in this mix....????
Thanks
G
DRBarnhart
Why?
What would that be?
You could use whatever parts of the controller you want but why not use it all? Seems like you're making it overly complicated which could come back to bite you if you need to do some troubleshooting someday...
Dennis
PS It appears you'll still need the 4093 for high/low...
GDOG_PITBULL
Why?What would that be?You could use whatever parts of the controller you want but why not use it all? Seems like you're making it overly complicated which could come back to bite you if you need to do some troubleshooting someday...
Dennis
Because I feel the controllers cannot handle the high current circuits!
Not sure what I need at this point.....
DRBarnhart
The controller was designed for it so unless you're doing something other than wiring the normal stuff you don't have a problem.
If you want to do away with the issues you're having you need to remove all the "creative" stuff and install the 4260 and 4093 as they were intended.
So since you're probably not going to do that... Good luck!!! ;)
Dennis
GDOG_PITBULL
The controller was designed for it so unless you're doing something other than wiring the normal stuff you don't have a problem.If you want to do away with the issues you're having you need to remove all the "creative" stuff and install the 4260 and 4093 as they were intended.
Dennis
Evidently the 4260 was not designed to do anything with a BDM.......
MossBerg590
Did you look into the boards? Not sure why you keep saying that it won't work because a lot of people have that set up in big dogs no problem. I don't think it is the module that's the problem here.
