Weird noise
TapioK
So this is the Weird noise I have... ideas?
Remember, lifters look good, inside the rockerboxes looks like new, compression is 190/187 (front/rear)
Also check your compression release to make sure the are not backed out mine made a similar noise and I found the rear compression release was stripped and backed out. Do you have any air escaping from them?
TapioK
Those were my first suspects, but I installed new ones like a thousand miles ago. Didn't notice them leaking, and they seem to move normally. My old rear compression valve practically exploded, replaced both. Sound is kind of similar though. Hmmmm.
Only other thing I can think of is after you check the hose take a look at your carb and mounting bracket to make sure nothing is loose or backed out inside. Probably not the issue.
chubs
:oldconfused:Is there air pulsating there, or suction?:oldconfused: I know I've heard that noise somewhere before, and it seems to me that it was on a vacuum pump with a bad check valve. (but I'm probably way wrong as usual)
TapioK
Pulsating, there was no real pressure.
Sent from my iPad using Tapatalk Pro
SMCT
Those are crankcase pulses. That is a vent that is in the rocker box area. You did a compression test, but if you do a leak down, you will probably see that it might have ring seal issues, getting blow by in the crankcase which breathes out that tube in the head.
Ya see, if the scavenge stage in the oil pump was properly engineered, it would absorb those pulses, but it's not because it's a shit design.
The ring package, even when new, is too light and you will have more then what should be for blow by. A blow by meter would show this up immediately, as it's a true way to test an engine dynamically.
I smoked some dope back in the day, but nothing like the dope that the engineers at S&S smoke.
Just think about this Tapio. Take one of your lit cigarettes and stuff it in that hole so the filter is facing you, then put your lips on it. Don't say I never helped you with a better cigarette design.
P.S. The actual noise is the flutter of that one way valve.
P.S.S. why would anyone want to put dirty contaminants back into their carb/engine? That shit is silly.
Spikes05
I was going to say check out the one way check valve that that hose connects to. The hose connects to the top of the rear cylinder head and then there's a one way check valve and then connects to the air cleaner backing plate. It is the crankcase breather.
TapioK
So you figure if the valve is stuck open, it might cause the noise? That would be nice few dollar fix.
That doesn't answer the question: do I -and if, then why- too much pressure in crank case... looking at Andy's answer I'm a bit nervous...
TapioK
Right, I understood what you say what I will do about it is more of a question
I'll go and see the local guy today and ask if he can do the leak test, also will check the breather valve (S&S Part #50-8122)....
I have 3 weeks before I go to Europe and I should come back like a week before Wichita meeting....
So if the cylinders leak to the case, I'm looking at least honing and new rings, then hope for the best? Depending how the cylinders and pistons look?
SMCT
It's a valve you can get out of Mcmaster carr. You should also take that 1/8th pipe plug out of the front cylinder head and install a fitting to allow it to breathe as well.
SMCT
My suggestion is to get a new valve and re-route that line up under the tank, towards the neck and down one of the front frame tubes, and under the bike. I used a clear line from home depot and happen to have a nice sleeve that ascetically looks great when the line is covered with it.
That line is routed to the air cleaner for one purpose, and that it is illegal to dump crankcase fumes into the open. It's an emission thing that Big Dog had to adhere to, no different than any auto manufacture. With poor engineering, all these crankcase fumes, blowby go right back into the intake change. This causes detonation and contamination of that air/fuel charge.
Like everyone else said just pop at the check valve first. And see if it's broke, it's easy to figure out it should only allow you to blow out to the carb side.
Stick it to you mouth and blow each side and see if it allows air both ways. Again should only allow air blown one way.
After you replace that you can see if you have any more damage. Cheap and simple stuff first.
It's just a standard one way check valve used on vacuum lines on Cars. Take it NAPA they can probably swap it out for $2-$3
TapioK
I don't do blowjobs
TapioK
So? what's the verdict ? check valve ? Did ya get it fixed? Such a mystery !!!
Hard to say, I am in Naples waiting for rear wheel pulley, or sprocket or whatever you call it, bike is in other side of the Florida.... have a little work to do and hope to get bike together around weekend and have time to ride it back early next week... we will see...
