Axel
Hi Curtis,
Thanks for the info. This is good to read (from my side...) I was not sure if my end test of the EHCs is good enough. I test the starter solenoid output of every EHC before and after potting with a 20 Ampere load for minimum 20 seconds. The current should not drop below 19 Ampere within this time. I think, this is already a bit out of the "real world" in my opinion.
By the way, do you know the power consumption of the Dacota digital speedo? I have one client, who had problems with his ignition, what fails for seconds when he drives faster than 150 km/h with 3000 rpm for more than 1 hour. His speedo fails also in this time, what indicate that one of the internal fuses, what is responsible for speedo, ignition and tag light limit the current for a moment. This effect is not happen when he drives a bit slower below 150 km/h. Beside of the question if a japanese plastic racer would be the better option for him, I would like to know, if the power consumption of the Dacota speedo is higher compare to the original one. I assume that the internal fuse limit the current at higher rpm and think about to increase it in the next EHC´s from 1,6 Ampere to 2,5 Ampere. However, these outputs need usually 1 Ampere and I´m a bit afraid to set the fuse value to a more than a double value, cause the harness cables to the speedo and tag light are not very thick...
All the best!
Axel
All the best!
Axel
