When to service your Forks
Thank you, I will try that. He just made a quick adjustment of the cable I think and it got worse as I think I said I can't get neutral from idle anymore and over all things seem to be clunky.[/QUOTE]
Cable adjustment won't help you find neutral he needs to adjust the actual clutch too.
Sent from my 2PS64 using Tapatalk[/QUOTE]
So no quick adjustment (it made it much worse right away), then he said he adjusted it back, it was still worse. At this point he motioned to me that he would have to go into the clutch to do more which is hat you are saying. So the bottom line is having it serviced is now about to cost me more money because it somehow created a problem that did not exist before? It enough of an aggravation now so as to make riding it much less pleasurable, especially not having this problem before. Even before his "adjustment" it was not the same. However, I could at least get it into neutral with enough fiddling and without to much problem as long as I got it in while rolling p to the light. I found problems in here but solutions were much less clear. Thank you...
