prairiehorse
05 big dog Ridgeback... Head work, karata open primary, digital speedo
Rip kit installed. Went through by Brew (amazing fellow)... Worked great for a bit 100 miles then riding along n everything shut off... Turned key off n on while rolling n it started up again... 3 min later SAME thing n battery totally depleted. FYI... Had new rotor, stator, regulator from Curtis....
Re barged n tried 3 different batteries... Varying from 12.7v to 13.1v (power off). Key on hit starter made an attempt to crank n then nothing.. Not even a click. Changed starters still same thing.. Nothing. Hooked up to car battery for a jump (vehicle off)... Pushed starter button and nothing. Disconnected green wire from starter n shows 12.4v with key on & Also when starter button pushed (which does nothing).
Thinking possible bad board in handlebars on start switch? Would that cause a short to deplete battery too?
FYI... LIGHTS/SIGNALS /TACH ALL LIGHT UP JUST FINE
So incredibly pissed off right now! Any help is GREATLY APPRECIATED
